I know its been asked..but how much of a gain will we see?
yes, u can get gains. lower pressure drop means a gain in lost boost to the manifold, and lower temps means more hp from the colder air.
yeah, there should actually be pretty decent gains due to heatsoke being minimal to none. as to where the tmic was sitting on the hot motor.
we are gonna do a couple runs my srt against his ms6. it runs a hell of a lot harder from 2nd up! very noticable diff, but not as big as the TBE.
There is absolutely no lost in boost spool with the CPE FMIC. The turbo actually spools faster than stock. I believe it is b/c the stock IC has soooo much pressure drop (2-3 psi) that it results in slower build of boost. Extra piping, core size, blah blah blah. Here's the proof:
Every mod I've made over stock has resulted in faster spool and even more sustained boost in the upper rpms.
how did the races go ?
