fog light wiring?
it should be prewired.... all you need to do is replace the turn signal/headlight switch with the one that has the fog light switch
And also add the relay and fuse into their respective spots I would imagine. Be careful if your putting some high wattage fogs onto the factory wiring, you will melt something.
hmmm.. thanks for the replies
is there a tutorial on how to do this? i probably won't be putting too high of wattage fogs in, just something that would match the stock headlights... any suggestions on where to look to find these?
I'm with you....I wanna know how to do it too.
