Rhino Ramps fit under stock Speed3?
sierra248
Contributor
2007 MazdaSpeed3
Anyone use rhino ramps with there speed3 for service and such? Do they rub when driving up? Also would it be possible to use 4 of them to get the whole car up in the air, they would have to fit in front of the rear wheels while on ground as you'd have to drive up all four at same time so i don't think this would work, but if anyone has these and would check or know already, I'd appreciate it. I need 2 anyway but there pretty cheap so i thought wth. Still need to know if they work just for front though!!!????
Tom
2007 Sunlight Silver Speed3 GT
i bought 2....not enough clearance :( would probably work if you put two pieces of wood in front of them to drive up onto first. I just returned them and bought a half decent jack and stand set
I brought the ramps from PepBoys and i attached some 2x4s to the front and it works just fine. I would put some anti-slip s*** on the wood though.
I made these, their 12' long without the ramps.
I had to build another 8' ramp so i could get the MS3 up there without scraping the bottom.
My neighbours think i'm nuts with a 20' ramp.
Rhino ramps (8000) worked just fine for me; $35 for the pair at Kragens. Yes, the bottom dark plastic piece underneath the front air dam does lightly touch the ramp on the way up, but that's the same plastic piece that each one of us bounces off curbs and steep driveways from time to time anyway. The ramps left no mark underneath, and were so much easier to get the car up and down compared to using jacks and stands for simple front end work.
ditto. I use them for everything.. oil changes, downpipe.. etc
