- -- 03 P5 / 23 CX-5 --
Can someone please just combine the MP3 ecu with the P5 part that controls the sport auto tranny?
funky, it's pretty quick.
just go to the passenger side front
pull back the carpet
take off all the 10mm bolts holding down the floor plate
wear gloves, lift the floor plate up (will still be connected to ecu)
disconnect oem ecu, reconnect the mp3.
(there is a bolt on top of the ecu wiring harness to loosen and tighten on)
and no you don't feel a damn bit of power
Last I read was reading about 10 in open loop, so it's still runs very rich under WOT...That's why I'm working on installing an AFC to lean out the mixture and keep the engine in closed loop....
Under regular driving it's trims the AF ratio to as close to 14.7 as it can..So it does not run rich/lean...
The largest gain is from the advanced timing...
EDit....Yes it's a direct swap...about 15 minutes..plug and play..
