question to anyone who has run this car at the drag strip, I have tried everything from idle launch , 2k 2.5k 3k 3.5k launches, letting it spin tires through 1st into second, gradually go to 6k with little wheelspin in first etc etc etc, my 60 ft times are between 2.36 and 2.42 at best, my et and mph are between 14.3 and 14.4 @ 99.4 - 100.8 mph, I can get the car to be consistent but I feel the 60 ft times are superweak, my mods are an ms CAI , XS BOV and a heavy foot. I have read from 2.0 to 2.2 60 foot times which i doubt (speaking about stock tires only) by other drivers which means I am missing something or there is some serious b.s out there, tires are at 33psi , I havent messed with the pressure to get my baseline at everything in stock form and the best runs for me are at 2600 rpm launch , moderate-medium wheelspin all of first to 2nd gear shift,and quick shifting although some letting off the gas as clutch is engaged. I think the times I have been putting up lately are decent basically 14.35 at 100 mph but considering that 100mph with good traction should be able to be a mid to high 13 second pass on a rwd car with similar power to weight ratio leads me to believe that 60ft times are more important to me than adding more and more power aimlesly. if anyone has suggestions (not looking for drag radials) on how to better my 60 ft times I am all ears , I honestly consider this car hard to keep consistent due to it's lack of traction and danger of being or not being on boost if off by a couple of hundred rpms.....thanks for any help
