Obx & T3/t4 Turbo Set Up Help!!!
Hiboost mani, then t3/t4, then custom hotpipe, intake pipe, and downpipe. ALso you'll need a 38mm wastegate and dump tube.
Nah its way too loud, plus you cant hear knock/ping...i prefer the high pitch sound of the turbo and the bov
Search around for Precision turbos, they make a shitload of different T3/T4 turbos.
How far out does that mani place the turbo compared to the SPOOL log manifold? I dunno man, I would even pick it up, but I love my log mani. What are your thoughts?
That tubular will spool faster, I dont know where the log mani places the turbo, but I have a few pics of the install...
here they are
Stainless Steels cracks very often by either rain, turbo weight, exhaust pipe hits, too small exhaust housing (excesive backpressure) etc.
Cast iron mostly crack because of heat expansion, it warps and the flangetries to keep it together, cracking welds (temp go down too fast when welding or welding temp too low for example) or turbo assy weight.
So that spool mani is pretty good?? What you guys think should I buy the mani or turbo first?? Money wise it can only be one part right now.
Turbo for sure It's the single most important piece in your build. The rest of your pieces will need to compliment it.
