timing?
no ok guys lesson 101 getting the msd dis for boost and wide band, fuel pump and all the s*** and running lets say 3 degrees per pound of boost and for every pound of boost not just retarding it period, yes just retarding it will make it run like crap,but will make the car fast and will not blow anything up.
bulls***, It sounds like you are well on your way to doing something stupid you your MSP that will make it break..
listen to Brian. he would know. (not that he did stupid, but he knows this engine inside and out; and has "been there, done that").
Those things are just tricks that were used on old out dated dstributored cars. These cars don't have a distributor, the ECU controls timing. With just a Unichip you can make way more power than you would by trying to use all those timing retard tricks. I'd rather be driving a fast car than a retarded car.
well good luck destroying your car...sounds like you are well on your way...
+1 again. i see now what he may have been thinking...
THis is the last time I will warn you man.
YOU DO NOT KNOW WHAT YOU ARE DOING! DO NOT **** WITH YOUR TIMING OR RAISE YOUR BOOST!
Take it from us guys who are now on our second or even third engines...
I would consider that a pretty serious warning...hopefully he isnt one of those super stubborn people who has to learn the hard way...
