lilchild87
Then what about getting CAI?? the air will be cooler than SRI and will travel faster than the custom mod we made.. it's brand is INJEN
What about removing the whole snorkel all together, just leaving the airbox with say a k&n filter in it?
The snorkel almost seems restrictive.
Although, I've never dealt with a car with a Helmholtz resonator in it before. So I could be off, and it could be very helpful, but its kinda weird thinking that putting more restrictions on the airflow will actually help.
Yes. To remove it, the MAF sensor must first be removed. The mesh, or screen, is a light press fit in the housing. I removed mine using a wooden dowel as a drift. Be very careful not to damage the internal components or you will surely ruin the expensive sensor. If you remove it and then decide to put it back, note that the screen is directional.
Removal gives you a bit more gain, particularly at higher rpms.
You dont worry about getting laminar airflow?
I dont seen my MAF screen as a shield for debris or anything i only see it for helping with the turbulent air.
I believe the function of the screen is to maintain the desired laminar flow (and prevent turbulent flow) as the intake air transitions from the air box to the MAF sensor, to ensure an accurate density reading. However, a number of sources have demonstated that removal reduces negative pressure in the intake duct thereby having a positive effect on performance. Additionally, as already stated, and as far as I can determine, I've experienced absolutely no ill effects running with it removed.
I agree with you that the screen is not a debris shield as the openings are large enough to pass objects of sufficient size to damage or destroy the engine.
You might want to try it as the mod is fully reversible. Then, if you find no benefit or note any problems, simply reinstall the screen.
Allright so just get like a wooden stick to pull it out and if i want to put it back in it has to go in the same direction it comes out?
Yea me too.. i mean dont be a cheap ass and **** up your engine.. remember that the cheapest thing is gonna cost you more in the future.. anyways this goes for the guy in top of me.. what about if i get this weapon r intake ans then connect an airhose from the filter to some place for cool air... or get injen CAI??
suggestions please.. thx!
because you are NA Id say get a CAI rather than a SRI. The colder the air the better. Even if you rigged up a SRI with a tube or something that is right in front of the grill and is forcing air in it will probably not be as effective as a CAI because you might be forcing more air in, but it is still hotter air. A CAI is the best bet for you I think, you will get colder air and a nicer growl from the engine than a SRI will provide.
In NA I always think a CAI is better... the only reason I run a SRI with my turbo is because it makes it spool faster, plus I dont need to worry about the difference in temperatures between CAI and SRIs because I have an intercooler that takes care of the air temperature!
Don't get a Injen CAI or sri. They both suck, i know cuz i used own a 1.6L protege, i tried everything from an Injen Cai, ebay intakes, and several custom made ones. You will get CELs like crazy with injen, cuz of the gay ass MAF on this cars.
And the best setup is the stock intake with a K&N drop in filter, you get more power. Then you can get some flexable tube and attach it to the stock air box and route cold air for the behind the grille. This is the best set up
Aight so keep the stock airbox and drop a K&N panel filter and then get this flexable tube from the airbox to the front of the grill.. something like this? one of those two..
Thx again for the help!![]()
