GT25R Real Potential and Capabilities
Personally i own a Mazdaspeed Protege 2003.5 with lots of work done around the GT25R Turbo, and Actually producing 271whp and 179wpt... i am open to any comments, suggestions eveyone can provide.
i hope you mean 279 wtq not 179wtq
I own the same ride as you do with lots of stuff done to it as well,my goal is to put as much hp as the t25 can provide so basically I am not changing turbos for a while ...Well at this time my tranny (diff)took a big s*** so I`m fixing it now(fidanza,exidy,new diff)on the way,and after that 3 inch turboback exhst...we`ll see what happens. but the t25 is stying for a while!
I'm putting 271whp and 279wpt with this little Gt25 demon child.. heres my car domain site so you can see all i've have done
http://www.cardomain.com/ride/2315771/1 the GT25 have lots of potential
Can you list your mods? I think you have a front mount...right?
Nevermid, im checking your cardomain page. So everything sounds right about you pushing 18psi, it may fall into an inefficient range, dont know yet, but the intercooler is keeping the charge cool enough.
You also running low compression 8.3:1 so if theres any extra heat escaping the intercooler, its good.
here you go buddie,,''
Garrett T25R Dual Ball Bearing Turbo Pushing 18.3 P.S.I of Boost on 106 Octane Fuel, Taking this Turbo a little beyond its Efficiency Limits, this little T25R baby It's Capable to Boost a max flow of 26.2 P.S.I for a few seconds gaining instant whp and wpt with this Mods at the moment: These are the recent Numbers: 271whp & 279wpt 313.6 hp to the Flywheel on Lates TBK Performance Dyno Results as today 01/06/2007
This Numbers had changed do to Lates Tune by TBK Performance 01/06/2007
Adding a Very more Aggresive Air/Fuel Curves, Also Retarding the Timing at High Boost and High RPM to the Haltech E6X Stand Alone Engine Management to Prevent any source of Detonation , Also a Upgraded Hiboost Front Mount Intercooler, 760cc Injectors, cometic thicker head gasket, Mazdaspeed BSpec Low Temp Thermostat from Protegegarage and a few more tweaks that TBK have done to the Haltech.
Engine: FS-DE 2.0 Liter
1. Honed and polished Engine Block. ( Done by TBK Performance )
2. Sandblasted and blackPowder coated engine block. ( Done by TBK Performance )
3. Crankshaft balanced and Polished. ( Done by TBK Performance )
4. Aries Forged Pistons Lower Compression 8.5:1 .20 Over Size
5. Pauter Forged Chromoly Rods
6. Mazdaspeed Engine Rebuild Kit. Main Bearing, Rod Bearing, Etc
7. Cometic Thicker Head Gasket 01/05/2007 Installed New do to Higher Boost Levels.
8. Greddy Timing Belt.
9. Full Head Job, Port & Polish Heads. ( Done by TBK Performance )
10. ARP Head Studs, ARP Washers, ARP Nuts. ( Done by TBK Performance )
11. Bigger Valves & Eibach Valve Springs. ( Done by TBK Performance )
12. ProtegeGarage Intake Manifold Single Runners port & polish. ( Done by TBK Performance )
13. Port & Polish throtle body 60mm. ( Done by TBK Performance )
14. Unorthodox Ultralight S Underdrive Pulley.
15. Gates High Performance Engine Belts.
16. Apex Air diversion Plate radiator.
17. Mazda Millenia Supercharged PCV Valve.
18. Maxspeed Magnetic Oil drain Plug
19. Mazdaspeed 1.3 bar Radiator Cap.
20. Mazdaspeed BSpec Low Temp Thermostat 01/05/2006
21. Mazdaspeed Gunmetal Oil Cap.
22. AWR 70a Bushings Front Motor Mount.
23. AWR 70a Bushings Rear Motor Mount.
24. SR Adjustable Cam Gears. ( Done by TBK Performance )
25. FS-ZE J-Spec 2.0 Intake Cam. ( Done by TBK Performance )
26. Walbo 255 in tank Fuel Pump. ( Done by TBK Performance )
27. Bosch 760cc High Impedance Injectors. ( Done by TBK Performance )01/06/2007
28. Perrin Fuel Rail. ( Done by TBK Performance )
29. Haltech E6X Stand Alone Engine Management Air/Fuel & Timing. ( Done by TBK Performance ) Reprogramming 01/06/2007
30. Haltech 3 bar MAP Sensor. ( Done by TBK Performance )
31. HKS Super Sequential Blow Off Valve Adjustable. ( Done by Dynamic Turbo )
32. HKS Earth Ground Cables System. ( Done by Dynamic Turbo )
33. Mazdaspeed Positive Charging and Voltage Stabilizer. ( Done by Dynamic Turbo )
34. Turbo XS Bypass Valve Recirculation Setup. ( Done by Dynamic Turbo )
35. Injen Ram Air Intake System
36. Apex Aluminum Cone Filter
37. HiBoost Front Mount Intercooler 29 X 6.5 X 4. ( Done by TBK Performance ) 01/05/2007
38. Custom Aluminum 2.5 Front Mount Intercooler Pipes & Flanges. ( Done by Dynamic Turbo )
39. Turbonectics Clamps.
40. Callaway Turbo Manifold Port & Polish. ( Done by TBK Performance )
41. Garrett T25R Turbo Port & Polish. ( Done by TBK Performance )
42. Cork Sport 2.5 S-Pipe & J-Pipe Port & Polish. ( Done by TBK Performance )
43. Mazdaspeed catback Exhaust System
44. Greddy Chrome Oil Catch Can ( Done by Dynamic Turbo )
45. Greddy Chrome Coolant Catch Can. ( Done by Dynamic Turbo )
46. NGK IX Iridium Sparkplugs ( One Step Colder )
47. NGK Coil Packs.
48. NGK Sparkplugs cables.
49. K&N 1008 Oil Filter
50. Royal Purple 20W50 Fully Synthetic Oil
51. Lucas Synthetic Oil Stabilizer & Protection ( New Engine Formula ).
Drivetrain:
52. Fidanza 7.5 lbs Flywheel. ( Done by TBK Performance )
53. ACT Xtreme Stage 3 Racing Clutch. ( Done by TBK Performance )
54. ACT Xtreme Street Preassure Plate Disk. ( Done by TBK Performance )
55. Welded LSD front and back of it, with special coating. ( Done by TBK Performance )
56. Racing Synchronizers. ( Done by TBK Performance )
57. Stronger 3rd & 5th Gear. ( Done by TBK Performance )
58. Techa-Fit Clutch Line. ( Done by TBK Performance )
59. Royal Purple Manual Transmission Gear Synthetic Oil. ( Done by TBK Performance ) 01/06/2007
60. B&M Short Throw Shifter. ( Done by TBK Performance )
61. KartBoy Shifter Bushings. ( Done by TBK Performance )
Brakes:
62. Brembo Cross Drilled & Slotted Rotors. ( Done by HP Motoring )
63. Techa-Fit Stainless Steel Brake Lines. ( Done by HP Motoring )
64. Posi-Quiet Ceramic Low Dust Brake Pads. ( Done by HP Motoring )
65. Royal Purple Synthetic Brake Fluid. ( Done by HP Motoring )
Suspension:
66. Tokiko Blue Gas Shocks
67. Tein S Lower Springs, 2 lower front 1.6 lower back. ( Done by HP Motoring )
68. Racing Beat Front Tower Sway Bar.
69. Racing Beat Front Lower Sway Bar.
70. Racing Beat Rear Lower Sway Bar.
71. AWR Front Lower Sway Bar Bushings.
72. AWR Rear Lower Sway Bar Bushings.
Electronics & Interior Accessories:
73. OEM Mazdaspeed Classic Soft Trim 2 Tone Leather Interior Dark Charcoal with Titanium Gray + Titanium Gray Leather Door Panels.
74. Greddy Profec B Spec-II Eletronic Boost Controller (Silver). ( Done by TBK Performance )
75. Greddy Remote Switching System Steering wheel (Silver). ( Done by TBK Performance )
76. Greddy Full Auto Turbo Timer (Silver). ( Done by TBK Performance )
77. Maxspeed Engine Start Bottom (Blue). ( Done by TBK Performance )
78. Autometer Triple gauge pod (Black). ( Done by TBK Performance )
79. Auto Meter C2 Indiglow Air/Fuel Ratio Gauge (White). ( Done by TBK Performance )
80. Auto Meter C2 Indiglow 20 P.S.I Boost Gauge (White). ( Done by TBK Performance )
81. AEM Uego 6 in 1 Wideband Controller (White). ( Done by TBK Performance )
82. Maxspeed Cluster Indiglow Gauges 7 Colors with Dimmer (White)
83. Street Unit Cluster Polish Rings.
84. Maxspeed Chrome Cluster Bezzel.
85. Mazdaspeed Seat Belts Pads.
Lighting:
86. Euro Black Smoked Head Lights.
87. HID Head Lights Kit. 8000k High & Low Beams. ( Done by HP Motoring )
88. Piaa Clear Rectangular Fog Lights. ( Done by HP Motoring )
89. Piaa Plasma Yellow H3 Fog Light Bulbs. ( Done by HP Motoring )
90. LED Ultra White License Plate Lights. ( Done by HP Motoring )
91. Mazdaspeed Carbon Fiber License Plate Frame. ( Done by HP Motoring )
Wheels & Tires:
92. 2006 Mazda RX-8 Shinka Edition Wheels 18 X 8. ( Done by HP Motoring )
93. Nankang Ultra Sport NS-II Tires Z Rated 215/35/18. ( Done by HP Motoring )
94. Gorilla Chrome Wheel Nuts. ( Done by HP Motoring )
95. Gorilla Chrome Wheel Locks. ( Done by HP Motoring )
do you have a picture of your GT28RS on the stock callaway mani ? i would love to see how it looks
Awesome that the GT28RS its Bolt on the stock manny, why did you manny cracked ? are you using EMS ? how mani psi are you boosting ?
yes its the GT28RS bolted on the stock many. I'm not sure how the mani cracked. when we went to installed the GT28RS we noticed it when we took the heat shield off.
i ran 14psi on the stock turbo for about a year on DSMconvert's AFC (split second psc1).
now i'm running the potato at jus a conservative 8psi using a basemap on my Microtech stand alone until i find a good shop to tune my car at.
I think its time u upgraded your turbo & tune mang.....You have quite a bit of work done for u to be pushing only 271whp. Ive seen members pushing almost exactly that on stock block/turbo and not even a 1/4 of your engine mods.
Im in no way putting your car down, but just wondering if u have plans to upgrade??
- Charles
- Charles
of course i'm upgrading my turbo. I just ran out of money. I'm getting Big turbo, Hiboost turbo manifold, external wastegate and 3.5" exhaust from TBK Performance which is Hiboost..
Obviously what its holding me from making big numbers is the turbo and teh exhaust.. pretty i'll be in 400whp with the right bolts on..
Mazdaspeed2oo35,
Sounds like the only things that you have left is a tublar exhaust manifold and the 626 intake manifold or a custom intake manifold and custom set of cams. Then it would be time for a bigger snail.
I have the NICK upgraded GT25R and it hits like a little sledge hammer.
I am running about 17PSI with the stock block and I have 113,000 miles now.
It has been ported, polished, ceramic coated and had GT28 guts stuffed inside. The manifold was ported, polished and ceramic coated.
With the 3'' GHL exhaust (among other things) it pulls so viciously that it has killed my 309 ftlb Spec clutch. Hopefully this spring I will install the new 450 ftlb clutch. I don't want to have it slip EVER :)
It has instant thrust and pulls hard all the way to redline.
I love mine.
nazgul350r said:
Mazdaspeed2oo35,
if you read my mod list on the bottom , i have 626 mani port and polish, fs--ze intake cam, valves and valve springs done. port and polish heads etc. ijust need the turbo, turbo mani, better exhaust, external wastegate and boommm........ thats it.. .400whp ...
