hey vds, what's the other electronic gizmo near gear lever? I'm very curios.
and regarding oil temp meter: was it difficult to fit it? have you had to drill somehow the block?
i have a authometer phantom ol presure gauge.. but I have not installed...
the msd dashhawk, from which it takes the signal?
ecu? interesting gadget
i need a install a wather temperature gauge...
I think you should have got an oil filter spacer which is actually the adapter for the 2 sensors, oil temp and pressure. The reading should be much more accurate using this method.
The DashHawk is connected to the OBD port that is in the cocpit,under the wheel.It has a water temp indication and many many others.
ohhh obd port... more better!!!
then you should also read the timming and the check mark
Never u try 1/4 mile?
