Thanks allot for your help...your thread had allot of good info in it...do u know how to make a switch so that if you are in gear the car won't start??
Thanks once again..
chas
P.S. you should ask the moderators in here to make that thread into a sticky in the HOW TO Section!!
Not a bad idea on the how to, unfortunitly I don't have the time for a proper write as I would like to do it with pictures and all.
Go down a little further in the tread and another memeber attached a relay setup that he used for the nuetral safety trigger.
The weird thing is I though all DEI products had a Black/White wire that was purely for a nuetral safety trigger. But most people ground it out when not using it.
Do a search for "neutral trigger", and go to the thread that was started by ELEmental. All the relevant info, a wiring diagram, and safety switch info is there.
