windows not working
stringsays
mazda cx9 2010
quick question on a 2010 cx9. it seems that none of my window switches are working. ive tried replacing the fuse but that didnt do anything either. it's a not a window reset issue, as i cant open up the any of the windows both from their respective switches or from the drivers door panel--meaning all 7 are out. all other electrical seems to be working. i know it's not the child window lock either.
any advice? what am i missing here?
Well, I might be totally wrong here but I am wondering if you have a faulty power window relay, which I believe is located in the master power window switch (driver's door switch) if that is the case you would need to replace the entire switch which you can find one used on ebay or a new one I believe is around $150.
http://www.ebay.com/itm/07-08-09-10...ash=item2f020bafae:g:-UMAAOSwYXVYywKT&vxp=mtr
But like I said, I could be totally wrong...
thanks for the quick reply...i really appreciate it. does replacing the switch mean i have to remove the entire door panel? or can i just pop that part off.
how would i figure out whether that's the issue at hand?
i really appreciate the help.
Hi, Im having Same issue. No windows working. Replaced fuse, replaced power relay too. Still not working.
On power relay, the power side mirrors are operational.
No clue
