Ventpod Group Buy Feeler!
Status
Not open for further replies.
Also, the center vent assembly the same part (that triple pod module). I removed the module from both a CX-7 and a 6, and they have the same part number on them. I even temporarily installed one unit into the other....identical! :) The CX-7 just has the extra foam added.
VRMS6, fret not, LT will add you. ;)
Add me for the driver side vent, in the mean time i will decide what i wanna do about the middle ones.
Here's the production representative center vent pod for the 6...
No photochop this time. ;)
Can you list the part number for the Mazda 6/CX-7 vent. Is it the same size as the RX-8? I want to replace my all black vents with the aluminum bezel vents. They only list the RX-8's online. Please help. Thanks.
Chris
If your vent has a part number prefix of "CJ6A", it's the same vent. However, the part numbers that are the same for 6 & CX7 are for the center vents. The outers are different numbers and are not common between the two. They are apparently the same size, and interchangeable, but I don't think they are the same part number.
I couldn't tell for sure from your post, but if I'm reading between the lines correctly, you're interested in two VentPods, yes? ;)
Tooling started!!
Okay people, we're going to kick off the tool for the 3 either tomorrow or Monday! Yayyy!!
We are going to hold off on the 6 for now. The center vent style pod will be our prime direction for that model, but we can't launch more than one product at a time right now.
With all the interest in the 3, it shouldn't be long before we can start on the MS6 Center VentPod. ;)
WHO NEEDS 2??!!!!(band)
Status
