Under hood LED light battery question
BTW, I'd get a cheap cooper washer from Home Depot as using metal washer for electrical current just doesn't seem right to me. It may easily cause corrosion at contact point between different metals with electrical current going through ...
Coopers are becoming more numerous the last couple decades with the resurgence of wines and spirits made in the old world tradition but they are still not plentiful or cheap! They need to make a living too.
Oh, did you mean "copper"? A copper washer is a metal washer. When you say "metal washer" do you mean ferrous? Because that's saying what you mean.
There is no problem using ferrous metals to conduct current but it would be good if it were plated or galvanized so it had some corrosion resistance.
+1 on corrosion resistance. Cooper is not needed in this application. Multimeters for president.
