Subwoofer Wiring Question
weitrhino
Charge & get yer horn wet
2003 P5 "Blackie"
So I'm wiring up a stock sub I managed to acquire some time ago. I'm cruising through the job, having never done one before, when I realize I have a wire I don't know what to do with. What the devil is the blue/white wire from the sub wiring harness? It has a 0.5 amp in-line fuse . I have no direct connect harness in the car already, so I'm making this up as I go. Advice?
cheers, weitrhino
Mike R said:
Prolly a switched 12V. The remote turn on.
Yeah, it's got 12 V from the battery, 12 V from accessory, and the third one with the 0.5 amp fuseable link. I guess I don't understand why it would be powered 3 times.
weitrhino
weitrhino
I'm sort of confused when you say "stock sub." Is there an amplifier that's powering the sub? Or is this just going straight to some speaker?
If this is going to an amplifier, then this would be the remote wire, as mentioned above. Basically, it's like an on/off switch for the amp. In other words, when there is a electric current running through the remote wire (i.e. stereo turns on), the amp will turn on. When the stereo is off, the amp turns off. This will prevent the amp from continuously sucking power from the battery when not in use.
For our stock headunits (or aftermarket stereos without remote wires), you can buy a relay switch (autozone, advanced auto parts, etc...). Now I'm no professional stereo installer, but I have this done in my car.
If you think this could solve the problem, then I'll elaborate further on how to wire it, but the relay should come with a pretty easy-to-follow diagram that I think you'll understand better than me. Let me know if you need more info. I could possibly take a pic of my relay since it's not far behind the dash. Hope this helps!
The stock sub for the 2003.5 was a powered sub. I'm installing one in my 2003, for which this was not available, so I have no wiring harness to just click into.
I was hoping I could find an unused connection point on the back of the OEM head unit that would power on/off with the front power button. I hadn't considered the relay switch and am very open to the suggestion. By all means, elaborate as if to a blank slate.
cheers, weitrhino
Hmm...well assuming this is a remote wire, using the relay is pretty easy. The picture I attached is a 4-pin pneumatic relay, and looks very similar to the relay I used in my car...only difference is that mine is a 3-pin, and 3-pins is all that is necessary for this application.
Looking at the picture, the two bigger pins provide power to the remote wire. One big pin receives power...let's say, from the battery or in my case, a fuse block. The other big pin sends the power to the remote wire, turning on the amp/subwoofer. The smaller pin is basically what switches the relay on or off. When the small pin receives an electrical current, it completes the connection between the two big pins...power from battery---to remote wire. When the small pin has no signal, the connection is lost.
So for example, I have a wire tapped into my stereo's power wire and then connected to the small pin. So when my car key is in the ignition, turned to acc., the stereo receives power, which also sends a signal to the relay, which then completes the connection from my fuse block to my amp, thus turning it on. When I turn the key to the Off postion, the stereo loses power, and the amp turns off with it, because the relay no longer receives a signal.
I hope this doesn't sound too complicated because it really isn't. I've never really been that good at explaining things. lol But if you have more questions, just ask, or maybe someone else with more audio knowledge can provide an easier way. Good luck!
Similar Threads and Articles
