Strange noise..
2003 Mazda Protege5
Alright guys, its time for "Strange noise from my P5" again.
This time, its a clunking-thumping-sort of noise but only when manipulating the clutch pedal, and only when under load.
I can feel something in the pedal clunking when it makes the noise, and is clearly audible in the cabin however there is no noise outside of the car at all.
Also this noise only occurs when in first second or reverse and lower speeds. For example no noise in third or higher.
I doubt it is relevant but any info helps right? I did get my timing belt, water pump, and accessory belts changed recently if that is worth anything haha.
Also a sound clip would be hard to get as getting my phone or a camera in the footwell and capturing the somewhat subtle noise would be difficult.
Bump...anyone?
Additional (most likely irrelevant) info: rear pads were changed recently and i put on enkei rp03 rims as well 17"
