T trashboat Member : 2003 mazda protege5 Aug 30, 2013 #1 Today I was attempting to take the rear sway bar off of my car to replace it with the new one I purchased. The bolt that holds the end link and sway bar together was spinning, but not coming off. Is this a fixable issue? And How?
B Brian_K Member : Protege5 Aug 30, 2013 #2 you'll most likely need to use a cutoff wheel to remove the nut.
T tweety2300 Member : 2001 mazda protege mp3 Aug 30, 2013 #3 End links should be replaced whenever they're removed anyway
M mp5la Member : 2002 Mazda Protege 5 Aug 30, 2013 #4 If you have air you might hit it with a ratchet. 3 out of 4 of mine were spinning and popped right off with an impact.
T trashboat Member : 2003 mazda protege5 Aug 31, 2013 #5 Thanks, I was just being real dumb, did not know there was an allen wrench needed.
