rca help
NOT2BAD
i have a cx-7 with the bose system and the 6 disc cd changer. i wont to put in subs but i dont know if there is rca in the back of the deck. need advice
No factory deck has RCA outputs. Best you can do it use the speaker wire outputs before the bose to jack into a typicle amp or the wires to the speakers to splice in speaker level signals to an amp that can take speaker level in or use a Line Output Converter.
On the 6's I know it is better to jack into the wires before the bose amp as everyhting after the amp is highly molested by the amplifiers processing
1. turn on the car
2. remove the head unit
3. grab the wiring harness that was plugged into the head unit
4. Pull as hard adn as sudden as you can, have a friend help.
Where ever the smoke comes from, thats the amp :)
Sorry its Sunday, I am still working, and I am into my 4th Rum and Cola
I dont know where it is, a seach will likey pull it up I know alot of people have accessed it for an array of fun tasks.
Open the rear hatch and take out the floor mat, where the spare tire is. It's under the driver's side rear seat.
have Best Buy or CCity install a high low converter. it saves the hassle of worrying if you did it correctly or not. AND the HIGH/LOW Converter is the piece you need to add an after market amp/sub
THis will not work to tap the wiring before the amplifier so that you have a clean and full range signal. IT would take a very low signal and make it even lower. These are used to tap the wiring going to the speakers but that signal is highly molested by the bose amplifier.
