radio fuse wire
2002 P5, 1978 F250
can anyone tell me what else connected to the wire that runs through the "radio" fuse in the fuse box. Like when taking it out what else is disconnected other than the radio. Im about to rewire that to the ignition wire from my remote start so that when I start with the remote it will turn the radio on as well. I cant run through the fuse because it has another sensor wire that cuts the engine off if the accessory is powered before the alarm is disarmed. Its kind of a weird setup but I just need to know what else is on there. (if anyone knows or has a wiring diagram)
Thanks
hmmm I don't really know...but a sure fire way of finding out is to turn on the car...and turn on EVERYTHING...and yank the fuse....that will tell ya whatever dies... :{D
SIMPLE BUT EFFECTIVE.
I'm assuming your Remote starter will work with a MTX. Bbbbecause I'm pretty sure that only a few of them will work with manuals.
Becareful cause the interior lamps are run through the radio's harness. If i remember right disconnecting the radio fuse with cut the dome lamp and map lights.
Yeah, i figured that was going to be the best way to figure it out. I'm a little hessitant to cut the wires from the back of the fuse box. I guess I will have to follow it from the radio and splice it there... I might as well just rewire the whole car with the amount of stuff im doing to it...
