quick response needed...removing headlight
Onatrum
2010 Hyundai Genesis Coupe
driver side low beam burnt out. I figured it's like any other headlight, twist to unlock and pull out. but the damn thing ain't twist'n. am I doing it wrong?
yes if you look in the manual it will show you a pic of what it looks like. There is a piece of metal or wire that you have to push in and then down. After that wire is out of the way then twist the headlight socket and pull it out and your done. The wire is behind the rubber cover.
