Hey guys, I'm back with more questions.
I brought my P5 in because my check engine light has been on with codes P0455 and P1250. My mechanic checked it out and found one more code that's appeared since I last checked. He tested around and told me that it's a problem with the PCM not grounding, because he could take a wire to each of the 3 solenoids associated with the listed codes and could manually ground them no problem. Unfortunately, the only place that can fix this problem in my area is the stealership.
I located and checked out my PCM this morning and I noticed this on the wiring:
Full size pic: http://i.imgur.com/R6skoEn.jpg
I also installed a subwoofer last summer, which required me jamming a fairly large power wire through the firewall in the tight enclosure the PCM wires run through, so I'm not sure if maybe that caused the problem?
So, here's my question: If you can tell from the above picture, does it look like the grounding problem could be because of that mess? Or is there a way that I can test to see if it's actually a wire problem and not the PCM? If it's the PCM, I'm going to just call around to some junkyards and try to find one instead of having to sell an organ to afford the dealership putting one in.
Thanks for your help!!
