oil blow by after turbo reinstall?
pbarton14
2003.5 MSP
Im having a small amount of oil blow by while im in boost but no blow by in vacuum. I just replaced the exhaust side of my turbo housing due to the other one having 2 bolts broke in it causing a exhast leak. this happened once before and it ended up being the oil feed line not being tight enough . Any ideas?
i looked under my car and seen oil dripping in my CS 3 inch dowpipe, oil is coming from the oil drain line on the turbo, i guess it blows by when the turbo is working hard?
Did you replace the washer on the banjo fitting on the line? You should probably just replace that or make sure the line is tight.
I will have to look at it , I confirmed that it's not blow by, its squirting onto the downpipe only when I stay in boost for over 5 seconds
