mp3 missfire
Good evening y'all so I have a 2001 protege 2.0 L it started running rough today. Runs fine when cold but when it warms up it runs rough and throws code p0300. I checked the coils what I could any how and got 93 ohms give or take. Any idea what I should check next?
I found this:
P0300 is random misfire. most common problem with that code is spark plugs and wires I have seen new spark plug wires be bad. 2 check for spark ,fuel pressure and compression that will tell you what direction you need to go
Source(s):
ASE certified auto tech
