Loctite for turbo studs?
tweety2300
2001 mazda protege mp3
Is there anything I'm supposed to use? I tried blue and red loctite and they've come loose for the third time now, I don't have enough room for using wire tie.
I'm about to jb weld them in
they make a loctite for high temp use. we use it on header bolt and works great. it looks like white lithium grease but when it gets hot it drys out and gets hard. comes in a white tube. might try that and get it to work. if not you could always get stage 8 bolts and studs.
I have stage 8 nuts those aren't going anywhere, and I don't have enough room for bolts. But I'll look around for the stuff you're referring to. If all else fails I'm just gona jb weld it
