brarsandeep
- '08 Mazda5
I just purchase an '08 Mazda5 from a private seller and he only had one key fob. I recently traded in my '06 MPV for a used Odyssey (growing family) and the dealer said that he did not have and key fobs and was being a jerk, so I only gave him one fob with the MPV and kept the other...I know, I know childish.
Anyway the MPV key fob looks identical to the Mazda5 key fob. I did a search on fob programming on the site and found this...
Step 1: Open [COLOR=green! important][COLOR=green! important]drivers [COLOR=green! important]door[/color][/color][/color] and leave open.
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Now, it everything does what it should according to the directions, except when I try remote #2 (Old MPV remote) nothing happens. Is there something I am missing?
Thanks in advance.
Thanks in advance.
