AGR#7 said:
yes, mine did too; with some spiking above 7psi. you haven't added any more boost Dex?
not yet, eventually
Dexter said:
not yet, eventually![]()
Turbo Matty P said:I raised the boost in my car without a gauge because I knew the fuel cut would shut it off before I reached 10.1 psi. My only problem is that with the MBC turned all the way out (no resistance when blowing through) it still hits the cut-off. It won't hit it in first but it crashes in second around 6K everytime, 3rd gear hits it at 5K. I can't wait for the new piggyback ecu to be ready. That should fix all of the problems we're having except the bump and stereo junk. The new piggyback will turn off the boost cut, eliminate the hesitation/stumble entirely, improve gas mileage (if tuned to do so) and increase power. There's no way I'm going to let that get away from me.
Turbo Matty P said:Well, the car feels much stronger, much more lagged (in 3rd and 4th), but not anywhere near 14psi. I still feel running 12psi or so is just fine with this set-up but I think my car is running more like 8psi and still hitting the cut off. Irregardless the piggyback ecu will cure this all and it'll have a "boost gauge" built into the program so I could just monitor it from....well, my monitor!
