I was wondering if anyone else noticed this problem, I am sure you did
I just installed my Joe P MBC and my Blitz DTT, I configured the MBC to stop at 9.5 psi by using my autometer boost gauge. After when I installed my DTT it stops a 65kpa which is pefect (9.5psi) but I noticed it only stays there for a split second and then it drops down in the low 5xkpa area, (7psi ish) is there any way to keep the boost level up higher for a longer time? or is the only way to fix this by replacing the fuel management system? such a waste of power,
also found a good online calculator http://www.chaseuk.com/conversions.htm
