Hey guys, a little question for you guys that lowered you your Mazda2, how do you center the wheels again? I know our rear suspension are like the VW's where the lower you go the more forward the wheel go, is there any way to center it again?
Either go with a narrower tire, or go with stiffer spring rates. The only other way I can think of is relocating your whole rear suspension setup upward, so when your car is at it's current height, the rear suspension will be pitched backward to an angle closer (closer, not close to.. depends how far up your relocate it) to stock.
Ahh I see.. Well I can't remember exactly how our rear suspension beam mounts to the chassis, but if we could use a plate like that, I guess that's something you could look into.
