HoW MuCh is Too Much???
It looks like the only thing you're missing is a pitot tube and a radar screen. You should install some sort of Heads-Up Display with altitude, bearing, and attitude measurements! Rice-tastic!
Buckle up.
Patrick
duMb KeoLa said:
lol, what the hell is that for??
That one will tell the Actual Air pressure in the outside..
@ sea level, normally you will see 14.7psi...
then think, if I the pressure drops because of weather, lets say, 12psi, then i can raise the boost 2psi or more and will be safe.
hehehehe:p
i guess it was a joke then, lol, being that im in hawaii, i doubt ill need it...but anyways, i think all id need left is some wings and itll look like a cockpit! lol, but i like the look, so imma go with it, thanks for the feedback
Here's my interior. What am I missing?
Nor do I see a navigator or communications technician. How do you expect to control pitch, roll, and yaw without your foot pedals?
LOL
Edit: That's actually got to be the purtiest cockpit I've ever seen. I'm used to seeing old 1970 pos's with kevlar and steel surrounding it.
LOL
Just use your Cruise Control AutoPilot switch to control all that, just remember to disengage it on turns, takeoff and landings...depending on what road you are cruising, you may use IFR, if not availabe, then VFR.
hehehe...
When my buddy crashed his S14 240SX, they took out the passenger air bag, and made a retractable guage pod. I'll try to post some pics. When you look in the car, it looks like a regular old air bag cover, but when you push on in, it retracts and reveals 3 or 4 guages, plus his turbo timer and his boost controller. Maybe you should go this route DK :)
duMb KeoLa said:
HOLY s***, that would be the sheit! can you post some pics??? make it more stealth mode i guess
No problem, I'll have to do it on Monday cuz I don't have access to a scanner at home (sorry, the pictures are regular photos, not digital).
that sounds really nice except to make sure never put your gf in the car.... better to be safe than sorry :)
aha all you need now is a grandfather clock with a white face and put it in your dash..maybe next you can switch to a jet throttle system...prepare for take off..haha..good work man..looks sick..but definetly ditch that jumbo tach..
