Ther are 4 screws that hold the climate control to the bezel, 2 on the top and 2 on the bottom. You will need a stub phillips head screw driver, or you will have to disconnect the cables from the heater control box to pull it out further.
I suggest the short screw driver that way you dont have to re-attach the cables.
