Yeah break in the sensor or it will mess with your head....i installed mine last weekend....although its coming out to go into the Colt Turbo rally car
...as for wiring the heater wires together yes you can do it but it will still throw a CEL as the extra resistance from being spliced will make the voltage too low and throw a CEL too I've already tried this. Your best bet is this....what I did was left the stock O2 sensor plugged in cut the signal wire adn spliced that one with my O2 sim it works fine no CEL you may want to try that. And yes the gauge is very accurate to 11:1 on the rich sid eas Terry said.....if you break in teh gauge a little more than suggested this reading will level out more.....make sure you set the correct setup level also you turbo guys it shoudl be set at the 11:1 setup calibration for me its at the 15:1 calibration cause my O2 sensor as it sits is way the hell down the exhaust lol
