Ok so the radio doesnt work and the display that shows everything isnt coming on. I tried switching the fuse under the hood that says audio but that did nothing.
actually you don't have to remove the glove box. If you stick your head under there you'll see a black plastic panel. Pull down to release it. Then you'll see a white fuse panel with a bunch of big plugs in it and two thumb screws. Undo the screws and the panel will drop down. Now you can access the fuses on either side of it.
