Extended Studs - Knurl diameter?
xcoldr1cex
2007 Mazdaspeed3 GT
Looking to put on some extended studs so I can accommodate spacers safely.
i've only really found
http://store.ichibausa.com/mazda2.html
I was wondering if the ARP studs that fit miata's (and protege's) will fit the ms3 - they have two different knurl diameters .577 and .509 inches. not sure what ours is. Does anyone know what the MS3 knurl diameter is?
I know we are:
Thread size: 12x1.5
Hub bore: 67.1
Lug pattern: 5x114.3
Length: ?
I used the ichibausa studs. I was having the same problem as you finding a size to fit. I think there is a ARP studs that will fit bu the knurl is different then stock. I have both sets, currently the ichiba studs are installed and working fine.
thanks turbo23, i'm going to go ahead with the ichibausa studs then, too bad they **** you on shipping costs..
why didn't you install the arp studs?
