R Rd02sir Member : 99 protege Nov 8, 2013 #1 Hey guys,, Ok, so my e brake doesn't grab. I changed the drums and shoes, put a new cable from the cabin. It's as if there is too much slack in the two cables under the car. Is there a fix for this besides changing the two cables? thanks all! andrew
H HLSilver Es Member : 2000 Protege Es Nov 8, 2013 #2 There's a little adjustment nut beside the e-brake handle under the center console. Try tightening it down and see if it helps. http://www.clubprotege.com/forum/showthread.php?46008-An-Easy-Way-to-Adjust-the-Parking-Brake Last edited: Nov 8, 2013
R Rd02sir Member : 99 protege Nov 9, 2013 #3 HLSilver Es said: There's a little adjustment nut beside the e-brake handle under the center console. Try tightening it down and see if it helps. http://www.clubprotege.com/forum/showthread.php?46008-An-Easy-Way-to-Adjust-the-Parking-Brake Click to expand... Ya it's maxed out.
