Dash Dyno SPD
enganear
'08 Mazdaspeed 3 Sport, Sunlight Silver
I just got my Dash Dyno SPD. I haven't played with it much, but I have a attached the results of a short run through 4th gear. I got wheelspin at the top of 1st and the computer shut the throttle. You can see the speed spike in the speed curve and the AF Ratio goes lean. In 4th I spiked to 18, dropped to 14, and tapered to 11 at 6k. The AF ratio at WOT was around 9.7 for the most part. Mods are crushed stock BPV and K&N drop in.
I can see there is a lot of power waiting to be unlocked if boost can be held and AF ratio controlled leaner.
-enganear
