Current Engine bay pics everyone
It doesn't look busy....it looks like you crammed 10 lbs of s*** in a 5 lb bag. But I second the props on your setup. You have to be one of the most powerful autos out there. Love the car Mark!
mine as of this mornin'.
Last week. I really need to start cleaning up the wiring and vacuum lines.
Actually, I guess this isn't current. I re-mounted the coolant bottle tonight!
Great looking setup man! Def. jealous!! Keep up the hard work...
Yeah you could spend hrs more figuring out how to run wiring and hoses better, it will make you go crazy!(crazy)
lookin good. i see my old parts :waves::
They say "hi". I'll probably be going with a new, different setup here in the next few months so it's looking like you old parts will exchange hands oncce again.
magnumP5 how effective is that strut bar?
I'm horrible when it comes to explaining perceived differences from mods but I definitely think this tightened up the front end a bit. The car definitely wanted to understeer a little more ever since the install but I've since added a larger rear swaybar so it's better now.
Thanks! It's definitely an ongoing process and I've still got a long way to go before I can consider it "done". Yeah, one of these days I'll make wire tucking my primary focus. I usually tell myself I'll do that after an IM, etc. install but by the time I'm done I just want to get everything together and drive it!
And where did you get it from....
Did notice you had to remove the cruise control...
It's one of the old CP Racing STBs. I bought it from another member around this time last year but they are not made anymore. We've had a few members try to go out on their own and get more made but nothing has been too successfull so far. Might be something in the works though... Yep, CC either has to be removed or relocated. I had CC with the turbo for about 3 months and I just didn't like how it worked with the turbo. It's quite "hilly" here where I am at school so the CC would cut throttle going down the hill than mash on in coming up the hill causing like 5 psi to be reached - not something I want to see in 5th gear.
IRCC if you like your Cruise controll you can't use that strut bar without having to at least delete or relocate the CC stuff.
Yep, I'm the in the process of completely removing everything. The only thing leave of my CC system is the controls on the steering wheel.
s***? okay, well thanks for the props anyway!!!(cool) i wonder how many other turbo'd autos we have anyway?
