Cost of Boring out cylinders.
LinuxRacr
Contributor
2001 Mazda MP3
People...or anyone who has ever done this,
What is the cost on average to do something like this? What are some pro's and con's you can think of?
if i can remember correctly, i paid roughly $150-200 to have the block from my triumph spitfire cleaned and machined. (deck resurfaced, bores machined, and dipped and cleaned) however, i removed everything from the block before taking it down to the shop. if you can afford having your car down and out, and are able to do all the work of removal and reinstallation, go for it.
what do you have planned?
Look here to see what I am up against. I was just getting the pistons, and Rod bearings changed, and they discovered that I had some gouges and scratches in my cylinder walls.
talk to the shop. maybe they can cut you a deal because you are having them do all this other work already.
If I remember correctly it cost about $15-$20 a whole, and you can't go more than +.0025 over. I was going to do this but then I decided on putting a sleeve in the one cylinder that was damaged that way I could reuse the 3 good pistons I had left. Sleeve's are more expensive, they are around $150. My shop did a Great job though, I couldn't really even tell which cylinder had been sleeved.
So if you decide to bore all the cylinders, I would try to find someone changing out their stock FS-DE pistions and grab'em! :)
Sucks to hear that you will be without your ride again :( Atleast for a little while it would appear. Hope it all works out.
I already have the stock pistons. A brand new set. They tell me that I will need some custom pistons. Is there anything else I could do?
How many cylinders have damage?
If you only have one cylinder with damage I would call your local machine shop and ask how much they would charge to sleeve your engine. Like I said it cost me around $150. But you also need to find out how deep the scratches are, if they are too deep then you will have to sleeve it. That was what happened to me.
Anyway you have to do some research to find out what you can do and what parts you can get. You can buy oversized(+.0025) pistons from the dealer but it is gonna cost you. I think they are $70 just for one piston and wrist pin. You will also need new rings if you go oversized which will run you around $210 for the set of four. www.mazdamotorsports.com has oversized pistons but they are 10.5 to 1 ($30 a piece)
You need to find out how deep the scratches are and how many cylinders are scratched, and then talk to a machine shop and see what they can do for you.
Could they bore out the one cylinder and then put in a sleeve to return it to stock piston size? That way you could keep all of your pistons... This is just my brain at work, I have no idea what they can do :).
Are sleeves ok for running boost though?
Chris
Ouch...how did that happen? Was your engine new or used? wtf?
damn linux, this really blows. i never had anything bored, so i wouldnt know what to tell ya, but it sucks about the ride again.
I meant to say sleeve the one bad cylinder. So yeah they sleeve the cylinder with the damage. Sleeves are just as strong as a stock cylinder if not stronger.
Another thing to think about is that in order to bore out the cylinders in our engines they have to remove the oil squirter thingy's. So you have to buy new ones. Not sure what the price is on those. Not much I don't think, but my machine shop had never seen anything like them before.
Yeah I saw the oil squirter things too. I have multiple cylinders that need to be bored. When you buy a used engine, be sure of what you are getting. I wish I could have goten my old block before they threw it away last month. It only had one cylinder that was bad.
Well, my block got sent to the machine shop yesterday, and I believe that they found me some oversized pistons. I hope to have my car back next week. I am optomistic.
hey Linux is there anyway you can take some pics of the FS-ZE pistons so i can compare the looks of them to my Mazdaspeed ones? Thanks
So are the oversized pistons going to be stock 9.1 to 1 or higher/lower?
So are the 10.5 to 1 pistons in good shape? If so are you planning on selling them? Just asking :)
BTW: WooHoo!! 800 Post! (wiggle) (drinks) (boobs) (hump) (hump) (hump) (boobs) (drinks) (wiggle)
