Code P0713
gap
03 mazda protege5
Hi, i just did the atf change oil on my 03 Pr5 and with the next 30 miles of use the A/T light begins to flash then i put the scanner and read the P0713 code that says: high input temperature sensor circuit transmission fluid.
Then i google and find:
Possible causes
- Faulty Transmission Fluid Temperature Sensor
- Transmission Fluid Temperature Sensor harness is open or shorted
- Transmission Fluid Temperature Sensor circuit poor electrical connection
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Possible shifting problems
P0713 Description
The Automatic Transmission (A/T) fluid temperature sensor detects the A/T fluid temperature and sends a signal to the Transmission Control Module (TCM)
can anyone help me find the solution to this problem?
can you tell me where this sensor is located?
thanks i`ll be waiting.
