J JAZ32*PD* Member : 2006 MAZDASPEED ATENZA G/T "CI" Mar 6, 2010 #1 Does anyone know if the MS6 has a factory camber adjustment??? or do you need camber kit/plates???
R Rez Member : '06 Mustang GT-Brenspeed Stage 3 Mar 8, 2010 #2 JAZ32*PD* said: Does anyone know if the MS6 has a factory camber adjustment??? or do you need camber kit/plates??? Click to expand... No, you can't adjust the camber with the factory set-up. You will need the SPC Adjustable Ball Joints--these will allow you to make changes to the camber. RPM & SU sell them.
T tunersteve Member Contributor : 2011 Mustang GT Mar 8, 2010 #3 Front - none, see Rez's post Rear - eccentric bolts near the center that connect to the lower control arms do allow some adjustment.
