alignment specs.
  • Thread starter Thread starter trekv2
  • Start date Start date
T
trekv2
is any instred in some alignment specs. for the MSP?
i just got back from the HUNTER advanced alignment class and did a alignment on my car the specs are not out yet for SOME alignment classes i know there not out for kauffman tire yet. if any one wants them illl post them.
I do not understand the words that are coming out of your mouth....j/k
Can you explain what you are talking about.
-Six
Does any one want the Stock Alignment specs. for the MSP? this is mainly for Auto-x ers.I have read a while back that some people want the Alignment Specs. Now I have them. AND before I type it all out i would like to know if any one wants them!
get it?
FRONT / SPEC / TOL. +/-
Left camber / -0.97Deg. / 1.00Deg.
Right camber / -0.97Deg. / 1.00Deg.
cross camber / 1.50Deg.
left caster / 2.02Deg. / 1.00Deg.
right caster / 2.02Deg. / 1.00Deg.
cross caster / 1.00Deg.
Total Toe / -0.10Deg. / 0.10Deg.
left SAI / 12.98Deg.
right SAI / 12.98Deg.
cross SAI
REAR / SPEC. / TOL.
left camber / -0.80Deg. / 1.00Deg.
right camber / -0.80Deg. / 1.00Deg.
total toe / -0.10Deg. / 0.10Deg.
Thrust Angle / 0.80Deg.
The only diffrence from '01 MP3 is the Total toe.
Cool I waqs wondering about this. Anyone know the limits on our car? Like can you put -2 on the front stock or u need a camber plates???
Thanks for the info, now I can get it set up to AUTO-X!!
So if I take these specs to the alignment shop, they can align it to these specs without any problems??
yes.
yes. you can as far as -2 Deg. camber the Tol. (Tolerance) is 1.00 +/-
meaning you can go to -2Deg. or 0.00 Deg. w/o being out to factory spec.
those specs have been around for months already on this board and has been since october in the Protege FAQ
