So you're comparing the handling of a perfectly sound car to one with issues? Seems legit.
Never had a rattling problem from steering column either. Actually only issues he had with his was vc gasket an timing chain tensioner. Which is to be expected with 200k miles. And also wheel hop was rediculous which was fixed with motor mount inserts
I'm not trying to argue but I'm just simply stating facts to your opinions.
And if you want to get technical they made cobalts for a lot longer than 5 years considering its basically a cavelier. Kinda like the Mazda 3 took over the protege and Mazda 6 took over the 626. Not quite sure what your hatred of cobalts is but have fun with that
your points are invalid to me as you probably had experience with only one cobalt verses me that has worked on over 1,000 plus cobalts.
Cavalier and cobalt are totally differnt cars. totally different. The cavalier was phased out as the design was aged and ten years old.
mazda 3 and protege....totally different cars. 3 is a hell a lot more reliable..nicer to drive...nicer interior.
again your points are invalid as I state facts and not opinions. Chevrolet had a tsb (I believe a recall at one point) for the steering colums. A cheap/temporary fix was to take off the steering column shaft and rotate it 15-30 degrees.
Cobalts have different suspension...better auto/stick combos. still junk front end. If you never EVER had to replace struts early, sway bar links very early, or the control arm bushings very VERY early, by god you have the ONLY one out of hundreds of thousands without that problem.
Also. Dont ask me about the 2.3 swap..I'm not too sure. all I know is its in a 2nd gen....it rips.
are you going to tell me that cruze's are cobalts now? or are you going to let that slide?
man...this is getting interesting.
I dont hate cobalts...the one we drive we have had all over the country already. to vegas (2x), michigan, pennsylvania, florida, SC, and of course missouri over a thousand times. its the reliable car as far as road trips go...but...again the front end is junk.
also the damn thing never handled well around corners. just like the SS cobalts that have over 70k...with torn LCA bushings...
ours started tearing at 52k, then again at 71k (after going over some of the deadliest railroad tracks) and again at 88k. this time I put poly bushings in...they seem to be holding well. My 03 protege is 5 years older than the cobalt and have the original bushings/ball joints. they are holding up great.
Cheap cars have their faults....and again cobalts have junk suspensions. SRT4s seem to be the only stout stock turbo car on the market....
OP: I knew you would like the MSP. They're fun. Now jump the ball and snag it before somebody else does. they're fun machines...just keep up on maintenance.
My next car after the protege appears to be a Nissan next. I dont hate mazda either...mine has been a pain in the ass...but it always starts and drives when I need it to.
EDIT: The Model Years for the Chevrolet Cobalt Started late 2005 and ended late 2010, to roll out the 2011 model year cruze. No end is near for the new cruze. The cruze gets 41 mpg compared the 30 highway I get in the cobalt.
