Yet another fast diesel truck running 10.96
that's what you get on 30+psi plus nitrous and maybe propane injection...
you can be sure that thing is running like 550hp and over 1000lb/ft of torque ;)
theres a guy around here with a dually, all he has is a boost controller and propane injection. he not only hangs but usually tears up the supras.
can a diesel engine handle that kind of abuse?
hell yeah, have you ever looked at a deisel engine?
especially the REAL diesel engines. I dont know if you still can, but you used to be able to get a caterpillar 8.0L diesel in GM trucks. THose things are ridiculously bulletproof. They can push upwards of 40psi on turbos the size of your head(shocked).
Its all about torque baby(headbang)
$600ish I believe...same as a nitrous setup...not sure how much propane costs though, based on our propane grill Id say its a lot cheaper than nitrous ;)
It's really hard to tell...but I believe that truck is from here. Here's a pic of it, and it does run a 10.96 in the 1/4....if it is the same truck, its from TS performance and has Propane and Nitrous..and runs tons of boost. (The name of the video is "ts"...so I guess its the truck)
