XM Radio Installed in 3s 5-Door!!!
Tha3Man
2014 Mazda 6 GT
Wow! Installing the XM Commander into my 3 could not have been easier if it had come factory! For those of you who do not have the DVD nav, and want XM in your car, you are in extreme luck! There is a perfect amount of space underneith the dash where the LCD normally goes for every piece of the XM install. It took me about 2 hours to do everything from start to finish, and I would personally say it looks professional. I did not even have to mount the antenna externally! You see no wires, and have the controller in the blank space between the audio control knobs. I know, I know, you all want pictures. I just finished it today before work, so I did not have time to snap anything, but I will try to get some posted ASAP! Email or PM me with any questions!
GOT ANY PICS OF YOUR HANDYWORK????
The Pics Have Arrived!
Here are the pics! Enjoy!
The Car:
The dash mount with antenna on top of the hide away unit!:
The controller mounted:
The Car:
NOT BAD AT ALL!!!
How long did it take
Maria said:
NOT BAD AT ALL!!!
Took me about 2 hours, only because I sat there and debated on how to set it all up. If someone just copied what I did, I bet it could be done in under an hour.
2 hours really isn't that bad. It could've been worse. Luckily you were able to do it flawlessly. Looks good though. (spin)
Thanks for the compliments! And if I do say so myself, you are not half bad yourself (wow) :D
(drinks) CHEERS TO THAT......You can't be that bad you do own a 3 ;)
Good job, looks good..
I dont like what Mazda did with the radio in the 3. it must be impossible to change the it.. not cool..
Actually, the stock radio is a snap to get out of there, and what is even nicer is that there is TONS of space left over if you get rid of it. It will be only a matter of time before someone comes out with a nice replacement bezel, and you could get a whole entertainment center in that dash once that comes out! Other people could only be so lucky to have that much space to work with!
did you have to buy/make a custom panel to fit the XM unit in? The stock dashboard doesn't have a little cutout for the XM unit. If you purcahsed the panel, let me know where I can find one. I plan on putting SIRIUS in my 3s when I get it June 1st. (too far away if you ask me)
I guess I dont have that problem. I have a flip out screen. The hot note..
Nice install, I am putting the XM in mine too. have had the parts for a while but I wont install it myself... going to take it to a place here and have it done.
Im going to use the Alpine CRA-1667RF, mount it in the ashtray with fold down pannel covering it.
You are correct in that the dashboard does not ahave a cutout for the xm display. But, if you do not have the MP3 or Minidisc player in your car, there is just a bunch of empty space behind there. I did not cut out a huge hole, only one big enough to pass the wire through. That particular kit came with the display and two pieces of double sided tape to stick it on the dash. So I cut the hole, passed the wire through, then just stuck the display directly on the panel, which covers the hole nicely. I dont plan on ever removing the XM from the car, but if I do, it would be to replace the entire head unit, so all of that stock radio would be coming out anyways. I hope this helps!
Looks very, very clean. What we need to know is the nitty gritty mounting details, what it looks like behind those trim panels, etc. etc.
Well done!
-Mirror
ah, I didn't know that it was stuck onto the front of the panel. I thought you put the XM unit through the front of the panel and had the rest of it laying in the empty space behind the panel. I didn't know the XM unit was that shallow and only stuck onto the front of the dash. I thought the unit actually sat INSIDE the dash.. My mistake!!
VERY nice install. Shame on the XM folks for not making it flush-mountable. Any reception problems with your XM??
Congrats
Jeff, Ohio
