WTT Rota Slips Red Lip 17x8.5 48mm offset For your stockers - sold
Status
Not open for further replies.
Dang...are these still up for grabs? My stockers (09) have only 1500 miles on the tires....
yo ill make the trade if you still have them.
Mine are painted Midnight Blue with 2k on them.
PM me with info. Lets work something out. I want some 17s.
DO you have better detailed picture. You have 2000 miles on wheels and tires? What brand of tires?
to center the wheel when you bolt it up.
How are the rota's working out for you? you like it?
yeah 16x8's color grew on me enough were i like them. I have no hub ring which is why im asking. my car has alot of vibes at 80mph not sure if thats cause one of the wheels wasn't balanced right or cause of the hub rings.
Which one did you buy? Your rotas only come in 2 hub bore. 67.1mm or 73mm
Find out first.
If you have the 67.1 than you should be perfect, Because the car is 67.1 also.
If you have the 73mm than you need hub rings. I would not drive the car like that. I have done the same thing and it vibes alot at higher speed. Very bad for the suspension.
ROTA SLIPSTREAM 16x8.0 48 5X114.3 73mm
ROTA SLIPSTREAM 16x8.0 48 5X114.3 67.1mm
Outside Diameter Bore is the wheel. 73mm?
Inside Diameter is the car. That is 67.1
You can order them from here
http://www.1010tires.com/hubrings.asp
You can aslo order the Aluminum to last forever, Or the plastic ones if you don't take out the tires much.
Good luck..
Find out first.
Good luck..
Thanks man. Yeah the site I bought them from didn't list them. hopefully the box I got them in has it noted out the outside of it.
Status
