WTF Fuel cut or detonation?
14LBS
03.5 MsP
I know that i have asked this b4, but i am boosting 81/2- 9lbs spiking to 91/2-10lbs and it doesnt do it all the time but it's the same jolt when you hit your governer kind like hesitates till you let off the gas. any clus or has any1 had a similar experience. :mad:
I think its a spark cut and its based on airflow, not actual PSI. So depending on weather,etc...you might be able to boost to 12 on warmer days w/o hitting it and less on cooler days...
You'd have to get a standalone to control timing, etc..
The fuel/spark cut is actually a good thing because it prevents you from destroying your engine...
perfworks said:
Well as the title reads we have learned that there isnt a programmed fuel cut in the MSP. The problem arises when the MAF meter is "maxed" out. It is a 0-5 volt meter. Some will experience a cut in fuel because the meter has read enough airflow to exceed the 5.0 volt limit. ALL THE PROTEGES have this . Not just the MSP.
Now depending on many factors the "fuel cut" will happen at different psi ranges for everyone. The denser the aircharge thru the meter (and what the temp sensor reads ) the quicker it will bottom out the meter. Also there have been cases with short ram intakes causing problems, by "washing" the filter with the radiator fan. It will cause an increase in airflow turbulence in the meter and throw off the readings. Either causing harm or good depending on the rpm and ambient temp. Also many meters have different starting ranges that are within factory spec. Some meters will run at idle 1.6 volts while some others run 2.2 volts. That .6 volt can mean the difference between running 8psi and running 10psi of boost.
Well just wanted to shed some light on a subject that has been overblown. There is no fuel or boost cut. It is just that the meter has reached its efficiency limit and the ecu doesnt want more that that much airflow thru the system. Your stock turbo was sized using all the stock sensor outputs. Since it was used in N/A vehicles then it was a safety devise because it would only compensate for about 20% more airflow. This is all that the engineers intended. I wish mazda wasn't in such a rush to bring this vehicle out and put some more thought into it. Well at least they gave you guys a great car to base some mods in with the LSD and larger axles. All you need is a larger exhaust & downpipe, FMIC and a piggyback (hint hint:D ) and you could get some great numbers from that little turbo.
no, it probally won't. Basically the ECU freaks out once the 5V max has been reached, so it cuts the fuel delivery for a few cycles.
the best way to get around it is to get the 80mm mass air from MPI and tune it with the piggyback..it will alleviate your probelsma nd allow you to run more, safer boost
Modern Performance Inc..the 80mm mass air allows much more airflow over the stock one., and yes you need the piggyback in order to tune the massair(since the stock ecu will have no idea whats going on when you put on the new mass air..)
