wtb: vics and vcts solenoid and heater controls.
As the title states I need both vics and vctcs solenoids. Also need working heater controls. My fan now only works on 2 haha
Edit auto correct on Droid sucks hence the bad spelling.
Ok, i have 1 brand new solenoid, (they are both the same) are you sure that both are bad? What did your code say cause im guessing you have a check engine light on. As for the heat only working on 2, you may have a bad blower motor resistor it is behind the glove box. This happened to me and that was the problem. I also heard that it may be because the contacts on the fan speed switch and dirty. But look at the resistor first its held in the heater box by the blower motor with 2 screws.
engine codes are VCTS no connectivity and VICS low circuit ...swap the two around and the code follows with the solenoid.
and im positive its the heater controls/fan speed controls. i can jiggle the knob/put it in a bind and it works intermittently on and off but works perfect on speed settings one and two. also the fan speed knob has alot of play/loose feeling to it.
edit: to clarify im having problems out of the fan speed knob...everything else works perfect
Are the solenoids the same as on the non-turbo FS-DE? I have a used one from my partout, but I'd probably need a photo to identify it.
I would say they are to me they look as they have a Mitsubishi symbol on them haha
