WooHoo! She's back to her old self
PhreekPhive
2002 Protege5
Got my sounds put back in =) He changed it a little so it looks and sounds better. The front panel with the 4 ch amp on it use to learn hard to the right, but he mounted it using a different technique and it's level now. And he adjust the freq on the front spekers so its more even thoughout the car instead of just the very highs hitting in the front. A day too late though...
It depends on the alarm. Mine is really sensitive so it would set mine off. But others, maybe. I never push it that much. The system itself is geared toward SQ instead of DBs, but I can pump it up if I wanted to. The gain on the 2ch amp is set at about 10% right now. No one appreciates SQ anymore :mad: all they want to know is DB numbers and hear car alarms set off :D
Just not on a saturday again, or I'll be at work. Unless you wanna all come over to my work and have lunch with me. Or if I get a 2 week advance notice I can request the day off, but then its still not 100% that I'll get it.
Alright, so I was tired of have my non fade level set to +7 for normal bass so I turned the gain to around 50%, it was already at 20-25%...thought it was 10%. Now I can have the NF Level at 0 and it sounds normal. Then I went to lunch listening to some Louie Devito. Pulled into a parking spot at Wendy's when a Zombie Nation mix was on and I pushed my NF back up to +7. Both cars next to me had their alarms go off. I'll never say anything bad about my DBs again, I promise. Leaving, one of the cars was still there and I paused it, unpaused it then paused it again. One hit is all it took. I think I'm gonna try this out at fashion valley mall sometime. Gotta go, gonna hang out at Hine with Randy and maybe order some parts I've been needing.
TurboBoostMazda said:
That's what I meant...! Do a San Diego run...!
cruise down on sun for the IMG cruise it's beign put on by group5, AEBS and modern image..should be fun
