Wires size for my Kenwood amp (1000w peak)
Jaldar
Hi!
I have a Kenwood (KAC-8151D):
Spec:
Max Power Output
1000 W (PEAK) 1
Rated Power Output
(4 Ω) 200 W (RMS) 1
(2 Ω) 400 W (RMS) 1
This amplifier power 2 subwoofers (spec: 600 watts Peak each (300 watts RMS each)). My amp has a fuse of 40amp.
What wire size should I use? I'am thinking about the 8 GA wires.
Thank you.
If you plan on adding a second amp in the future I would plan ahead and buy 4 GA...but for now you are fine with with 8GA.
Thanks for you awnser! I have more questions:
- How do you determine what wire size should someone use?
- Also, I have dimming lights each time the bass give a big hit. Is it myground or my wires size (I have 8 GA)?. Should I buy a capacitor?
Thank you.
Thank you.
- By the amplifiers amperage draw. (RMS power)/12 = Amperage draw
In your case thats 33.33 amps so 8 gauge will handle it. I like to run 8 gauge for up to 40 amps, 4 gauge for up to 100 amps, and after that 2 or 1/0.
IASCA would use the below chart:
<TABLE><TBODY><TR><TD> </TD><TD class=example>
Length of run (in feet)Current 0-4 4-7 7-10 10-13 13-16 16-19 19-22 22-28 0-20A 14 12 12 10 10 8 8 8 20-35A 12 10 8 8 6 6 6 4 35-50A 10 8 8 6 6 4 4 4 50-65A 8 8 6 4 4 4 4 2 65-85A 6 6 4 4 2 2 2 0 85-105A 6 6 4 2 2 2 2 0105-125A 4 4 4 2 2 0 0 0125-150A 2 2 2 2 0 0 0 00</PRE></TD></TR></TBODY></TABLE></P>This is a bit paranoid compared to the typical engineering table so its usualy ok to go left a column.
- You can try one if its to help the head light dimming, it will not stop it. You will need a good quality 1 farad cap. Stick to a maker like stinger or Monstercable and only use the cylindrical ones. I would HIGHLY suggest borrowing one from a buddy or something and see if it helps at all before spending money on one. Typicly they do neat nothing.
Also, you may want to just go to a 4 gauge ground and then do a set of new 4 gauge ground cables from the negative battery terminal, to the body, and to the engine.
Thank you for you anwser!
-What is the difference between cylindrical capacitor and a cap that is not cylindrical?
- Also, Is it better to have multiple 4 ga ground when all my audio system is wired with 8 ga?
- Finaly, is it ok to have a 3 farad cap for a 1000 watts peak system? (is it too much: will it cause problem?)
Thank you
I think the rule of thumb for caps was to have 1f per 500w but people have been questioning the necessity of caps the past few years. 5-10 years ago installers wouldn't even consider not putting a cap in. Now, most just upgrade the battery and leave it at that.
You could use multiple 4ga wires for an install but with only a 1000w, one will be fine.
All of your other questions about capacitors can be answered on this page:
http://www.bcae1.com/capacitr.htm
Read up!
Read up!
ok thank you.
Oh and one more question: do I need a distribution block or I can wire my capacitor directly to my battery and amp?
And do I NEED to ground my capacitor at the SAME place that my amp ground?
Usually you place the cap in-line with the positive cable going to the amp and ground it with a separate wire to the same location the amp is grounded.
Thank you all!
I have two more questions:
-What is the difference between a cylindrical capacitor and a cap that is not cylindrical?
- Finaly, is it ok to have a 3 farad cap for a 1000 watts peak system? (is it too much: will it cause any problem?)
Thank you
Rick
