I never really realized how wimpy the horn was until after a week I took my GS home. I called the dealership and told them that something wrong, when I arrived, they told me there was nothing wrong....it really sounded that way. (whip)
I was hoping to replace mine too, but would it void any warranty on the electricals?
Any alteration from the original normaly can void a warranty. That was why I patiently waited for my basic to expire. Although changing a horn is not a big job (only one wire for one horn), any short can mess up other components. I disconnected the battery before I did this operation as with any electrical work.(mj)
That was the first thing i removed . The wimpy horn .. And in stalled 2 Air horns.Sounds great..(cheers2)
I installed a set of air horns.
Sometimes other people still can't hear.
I was looking for something louder than OEM, but a little more subtle....
Certainly one can get something that works that mimics the sound of a Bimmer's horn(??)
where is the horn located? looks pretty tight inside, sounds like its buried on the drivers side, but usually they're located in front of the radiator, though I don't see it.
Here's what you want: http://www.bikerhiway.com/stebel-nautilus-compact-motorcycle-air-horn-black-p-74.html
If you go to Stebul.it and look at the products link, you can go to the page for the Nautilus Compact and listen to sound samples. Very similar to BMW and Audi horns.
Thanks for the help, but when I click the link above, it takes me to a motorcycle-only page. When I try to put www.stebul.it in my browser, it doesn't find anything. (cryhard)
The horn is on the drivers side, next to the radiator, you're right it's a little tight, but if you remove the drivers side protective plastic in the front part of the drivers side wheel well you should be able to get to it without removing the front tire.....you'll want to raise the front of the car, or drive up on ramps..... I'm getting ready to install fog lamps, so I'll take some pic's of where the horn is once I get in there......
You will be my hero for the pics and tutorial - I've decided to do this mod, but haven't been relishing going in blind.
