pluto316 said:WMA - THE WINNAHR
I like WMA more, but that's only because I have WinXP on both of my computers.
there is no point to re-encode to 320kbps. Remeber: Garbage In, Garbage Out. You will not be increasing the sound quality if the WMA was encoded at 46kbps or something equally as lame.ricenudles said:get winamp, decode wma to wav, and encode to 320 kbps mp3. that shiet is the bomb. wma blows. *edit* and no, it wont play wma.
dude, it's been answeredSirJaime said:JUST PUT THE DAMN THING IN. IF IT PLAYS, THEN IT WORKS! But to the question , YES it does ! T he question should be will KENWOOD play wma(rockon) (smoke)(stoned)(hippy)
Most of my music is 320kbps. Not because I decoded then encoded but the music I get usually is at 320kbps cbr or 192vbr. Personallly, I prefer 192VBR. I *think* its better. Watch out though, converting them all to 320 takes up mucho space on your hd.All Boost said:ricenudles - How much musik do you get with 320 kbps mp3? I'm downloading that acoustics program to convert crap, hoping to finally take advantage of the mp3 player.
That's absolutely true. But, in the cases where the .wma file or the .wav file ripped or downloaded are pretty high in quality, you could convert it into a high quality .mp3. Otherwise, the program you use wont let you select a higher bit rate and you're stuck with 64 or 96 bit garbage.Dexter said:there is no point to re-encode to 320kbps. Remeber: Garbage In, Garbage Out. You will not be increasing the sound quality if the WMA was encoded at 46kbps or something equally as lame.
